Quote:
Part Number: 51626
UPC Number: 765809516267
Principal Application: Dodge Monaco (91), Eagle (88-92), Jeep (87-93)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.812
Outer Diameter Top: 3.663
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 370
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
I looked but couldnt find anything, If you know of one please tell me so I can get it next oil change.
Part Number: 51626
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.812
Gasket Diameters
