GM 3800 Series II with Eaton MP90 SC on a 2000 Buick Regal. The SC appears to be going bad, will know results of diagnostics from dealer on Mon. A high pitched whine that gets louder as RPMs increase etc. Yes, SC do whistle but I have had this car a while, definitely a huge increase in the whine/whistle level. Also a check engine light that appears to be the Mass Air Flow Sensor. Not sure the two are connected as the whine started weeks before the light came on.
Anyway, question is, due to the cost of replacement can this engine function perfectly fine with a shorter drive belt and not engage the SC pulley ( actually not sure if the belt drives more then just the SC) if just the SC can the engine run fine without that belt and or a shorter one?
I would lose 40HP but I can live with that. Does anyone know if this is feasible? A rebuilt or used is a possibility as well but will it run fine without the pulley engaged.
thanks
thanks
