Can a warped disk brake cause wheel to shake?
Texas
If you have a warped brake disk, can it cause the steering wheel to shake, even if you're not pressing on the brake pedal? I have a vibration that becomes noticeable at about 60mph and up. I've rotated my tires. Balanced my tires. Got some new tires. And, I know I have at least one warped disk, and will be doing my brakes soon. I'm just not sure if that's what could be causing my wheel to shake.
Any thoughts?
I'd love to know the answer to this as well. I have the exact same symptoms/issue.
Thanks for posting!
Yup! Even when not braking. So can loose wheel nuts or bent wheel. Out of balance and mud on the inside of the wheel as well.
Tread separation too.
I have had rotors so warped that yes it would cause it. But they have to be pretty bad. Believe it or not its usually the tires, even new ones or a bad balance.
If it is vibrating without the brakes being applied it is most likely a tire issue. It could be rotors or a pad issue, but it is most likely a tire. I had a set of tires that were just difficult to balance. I finally took them to Discount Tire for balancing. The store is new and they have terrific equipment. They were able to balance them correctly and it removed the vibration. Some types of rims require slightly different weight types. Our Toyota Sequoia used different types of weights vs. our Chevy Tahoe. It was strange. It could also be a tread separation (as mentioned) or a bent rim or loose lug nut. Lots of variables.
Does the vibrating get worse when you apply the brakes at those higher speeds? If brakes/rotors are the problem the vibration should be accentuated when they are applied at those higher speeds.
A couple of things.
Always tourqe wheel lug nuts for disc brakes. Differant tourqe on the nuts can cause the rotor to warp over time.
If a caliper is sticking it will always put pressure on the rotor because it can't release. If the rotor is warped then you will feel a motion in the steering wheel.
It's wierd, because sometimes it will accentuate the vibration when I apply the brake, and other times not.
And, I'm pretty sure it's not the tires (could be rim, though). I had a set of yokos that were only about 2/3 worn and wobbling like crazy. Got them balanced a few times. Then just gave up and got new michelins. Wobbles with them, too.
One pad on one side of the rotor compared to the other? Or how the left rotors pads are wearing and the right rotors pas are wearing? Or both?
Edit: Ok, that made a lot of sense in my head, but not so much when I typed it.
What I'm asking is: Do I compare the left caliper's pad wear to the right caliper's pad wear?
That pretty much sums it up. If you rotate the tires and the shaking moves from the front of the car to the back of the car you can safely rule out the rotor.
It doesn't take a whole lot to warp a rotor, especially if it has been cut. Car makers have been using lighter rotors to save weight on cars, and warped rotors have been a problem.
Both brake pads on the front axle should be wearing out at pretty much the same rate.
Have you checked that the rim is not bent and your tire is round? You can try swap fronts to rears.
Warped rotor (not chipped or cracked) seldom cause shake if you dont brake. If your caliper stuck, you should hear some noise or feel the brake drags, especially if this in front, the steering may pull to one side.
Other possibility is your tie-rod and CV joint, I experience car that the CV joint is going bad also has vibration.
Are you on stock rims? Aftermarket?
Many people on aftermarket wheels have vibration issues if they did not have the correct hubcentric rings installed. The lug nuts cannot do a perfect job centering the wheel.
