dnewton3
Staff member
I'd like some thoughts on bypass systems, but I want to qualify what I'm asking and why. I do believe that bypass filtration is a good idea for those who intend to extend OCI's. It makes economical sense if you can cost justify the expense of the filter system compared to longer OCI's. This much I agree with.
My question I pose for discussion is this; can you extend your life of your engine by using bypass filtration, or are you just extending the life of your oil cycle?
It is my contention that bypass filtration does not add to engine life, but only makes the useful oil life last longer. We can all agree that oil does not wear out. The additive package gets depleted and the contamination accumlates, but the oil itself does not really wear out. Bypass filters can only filter, they cannot add.
With this in mind, consider two people with identical engines. Joe uses regular OCI's with regular oil analysis and develops a reasonable OCI expectation. Jim uses bypass filtration and oil analysis for longer OCI's. Who's engine would last longer? I say that as long as Joe changes his oil frequently enough (although not wastefully) his engine will last as long as Jim's bypass filtered engine.
I am aware that bypass filtration draws down much deeper into the micron world, but isn't the design of today's oils so much better that the effect of super filtration would be the somewhat negated by simply changing oil more often?
Again, it's not a question of financial effectiveness. Given a sump large enough and a proper bypass system, the super filtration makes monetary sense. I'm talking about which engine would actually last longer?
I believe that with today's beter made engines, and better made oils, each engine would last so long that Joe and Jim would be old and gray (and probably dead) before any significant event would transpire regarding oil related failure.
Consider this also. Bypass filtration routes roughly 5% of the total flow into the bypass filter. That means for every 1 particle of small micron size it catches, 19 more go right past the junction where the oil path gets the super filtration. So in effect, for every 5 quarts of micro contaminated oil you bypass filter, 95 quarts still go right to (and through) the full flow and back to the engine. Yeah, I know that they will eventually get picked up, but still, 19 out of 20 times that particle gets right back to the engine.
I am aware of all the web pages for FS2500, OIL Guard, Amsoil, Motor Gard, etc that show particle size comparisons pre and post filter, but I still contend that they improve oil life, not engine life.
I belive that bypass filtration DOES NOT make any engine last longer, it makes the OIL last longer. With regular OCI's and analysis, a conventional system does nearly as good a job.
With all this said, I do lust for a bypass system because it is vehicle love to the nth degree, but I don't believe it will make any engine last longer.
Let me put this another way; do you bypass filter your laundry water????????
