I've read numerous posts about bypass filters and whether they are really effective in keeping engine wear down because by their very design they are filtering out the wear metals themselves.
Has anyone ever done a study on this? I haven't seen any.
If not, then I have a possible solution. What about taking two samples from the same vehicle from two different spots? Take one from the supply line to the bypass filter and take one from the return line. Compare the two results and you "should" get an accurate indication of how much the filter is skewing your analysis results.
Granted, this is much too small of a test to be truely scientific but it would be a good indicator IMO. If this method was repeated enough times on many vehicles it should be fairly accurate I would think.
Any opinions?
Mikie
Any opinions?
Mikie
