Your indicated pressures and quick build up of oil pressure seem fine.
However, you need to be certain that you are measuring the oil pressure AFTER the filter assembly, and are not measuring the pressure between the feed from your oil pump to the filter assembly. You want to know what the oil pressure is as it goes to your engine's main bearings, not what the inlet pressure to any filter is.
It would be interesting to know what the pressures are with just your original full flow filter in place (i.e., without the adapter plate and Amsoil assembly connected).
