Bubbles in radiator neck after replacing breather hose
From the fourth cylinder
After that many air bubbles came out the radiator thte coolant level should have gone down noticeably, which I didn't see happening. That would indicate
1. Air forced into the coolant system, i.e. headgasket etc.
2. An opportunity for air to be ingested into the system from a hose that feeds from the expansion tank directly into the coolant flow.
After these procedure and after the engine get cool, the level in tank was dropped about one inch.
Is it normal when the thermostat is open to circulate like this?
lets start this out from a fresh point of view.
I am thinking you just changed the coolant
and you are seeing some bubbles in the radiator.
my question is have you driven the vehicle far enough to fully warm up the engine
and rechecked the coolant level
and then drove the car some more in regular service
and have you had any issues?
I was replaced breather hose which goes from the engine to the throttle body. Yesterday I was driving the car and after parking I saw some coolant under the radiator cap. I suspected the radiator cap. Did this on video today, warmed up the engine nicely and after 2 hours the coolant level was an inch below the mark line in reservoir tank.
