Originally Posted By: Dave9
Originally Posted By: Kibitoshin
If you ever dealt with brake systems in 10 or 20 year old vehicles I'd rather change brake fluid as a PM. I had to service the brakes on a 1990 Toyota 4Runner and everything was rusted internally (rather this brown gunk when I disassembled one of the whel cylinders.) After new wheel cylinders and calipers the fluid could never appear clear in the MC reservoir after a few weeks. The proportioning valve, ABS block, calipers and brake drum cylinders are made of iron so the high moisture level in the original fluid rotted them internally.
Absolutely, I do not mean to imply that brake fluid should never be changed, only that by itself in a properly working (undamaged/new) brake system, it cannot degrade to a visible water state in the FIRST two years. However I don't usually see significant internal rust from infrequent fluid flushes, rather the rubber components wearing and soft lines rotting inside caused the browish-black fluid color once they get that old.
LOL, visible water state.
Brakes with 3% of moisture are already having boiling point below 130c, and will create air pocket. Visible water state? No wonder we have som mane deaths in this country.
