Originally Posted By: Jtgrant
Can I get the short and sweet version?
You don't get the same level of education when someone else tells you what a paper says. The graphs and charts are informative and easy on the eyes. Aside from that, the Conclusion is a good place to start which is shown below but it is stated totally in generalities:
Originally Posted By: paper
CONCLUSION
In this paper I have attempted to demonstrate that the
physical properties of a lubricant are extremely important
in determining both the minimum oil film thickness in key
lubricated contacts, and the associated friction losses. It
is important to use models for the piston assembly, the
engine bearings, and the valve train, that include
accurate information about how the lubricant viscosity
varies with temperature, shear rate, and pressure.
We have compared a conventional gasoline engine with
a high performance Formula 1 engine, and shown that
matching the lubricant to the engine can lead to
significant reductions in engine friction, with consequent
improvements in the available power to the wheels.
