In a recent thread, the opinion was voiced that wheel lugnut/bolt torque was not critical. I remember from a long time ago that the target torque for any critical bolt is calculated by a formula. Unless a bolt has been stretched a certain amount it can't act like a tension spring. It is this tension that keeps the bolt from coming loose. The target torque depends on the bolt grade, bolt diameter and the coefficient of friction. After the target torque has been calculated the specified torque is then established empirically. The least predictable metric is the coefficient of friction, which is why torque is usually specified for dry hardware.
Target Torque in inch pounds = coefficient of friction x bolt diameter in inches x bolt's desired tensile load in pounds.
Do I remember this correctly?
