Originally Posted by exranger06
Originally Posted by BigChief
Did you ever find the cause of the Brake and Dynamic Stability Control lights staying on yellow?
Yes, my mom eventually took it to the dealer and got it fixed. They replaced 2 ABS pressure sensors - "ABS Pressure Sensor 1 and 2."
The part # for the sensors is 34-52-1-164-458. They're also apparently called DSC Pressure sensors. The light hasn't turned back on since then.
Thanks for the info. My issue turned out to be a faulty Steering Angle Sensor. My airbag light was also on.
A German car shop quoted me $1,100 to fix since you have to remove the steering column. I just don't see why these so called luxury cars can use such cheap components that would fail after 80k miles.
