BG 44K Fuel Additive
Based on what?
The only thing missing here is some acetone... smh. 😔
Even in its current form you could probably use this stuff as paint remover.
@USA get yourself some Red Line Si-1, Chevron Techron, or AMSOIL Fuel System Cleaner, and don't worry about the BG 44K.
Based on what?
According to this gentlemen that tested these cleaners for PEA content, BG44K has one of the highest. Any of the PEA content products will get the job done according to anecdote evidence at BITOG.
Based on what?
At most, the SDS accounts for 77.5% of what's in the can. At the least, it's 26.6%
It's almost like the SDS provides next to nothing useful about how a chemical works while providing helpful information about what harmful compounds are inside a chemical and how to safely handle them.
Weird.
44K + MOA + Italian Tune Up = Placebo for Cheap Customer that really needs top end work.
Made a difference in my DD Corolla after years of Techron use. Car had more power (back to original?) but when driven normal, documented increase in MPG. Working off hours with little traffic makes that easy to check when each tank is filled up all the way (topped off) and written in log book.
Not placebo with same results in other vehicles. Never needed top end work. 40+mpg on highway trips with over 200k on vehicle.
Mileage went down after swapping tranny fluid to BG Synchroshift II. That eliminated light grinding between gears especially at higher rpm's. That made it fun again to be close to redline which kills mpg. ;) 😁
I'm glad it worked for your Corolla!
