Bent Connecting Rod - GM Top Engine Cleaner
Originally Posted By: Trav
I guess he will be doing this job the safer way from now on. I bet he is kicking himself for not pulling the plugs before cranking it over again. As Frank said "killed it with kindness".
He has resigned himself to writing out longhand, "If it isn't broke, don't fix it" x1000
Originally Posted By: Vikas
could it have ingested that much all on its own when he purposely stalled it? or was it strictly because he added extra helpings afterwards.
BUT, how did he add the extra helpings? Is the engine orientation such that it is possible to pour something in the air intake using gravity?
Or did he take out the plugs and added more and put the plugs back? That would need huge slap on the forehead!
He added more after the engine was shut off - his big mistake.
if you add it via spark plugs, then surely you would just blow it off before putting back the plugs again.
We all makes mistakes, threads like this make me feel better knowing I'm not alone!
