I'll update probably early next year, when I perform the same PM (if the battery is still good-to-go).
Last update:
I was able to raise the specific gravity to just BARELY in the good region (1.250); however, the other low cell still indicates between 1.225 and 1.250, in that big blank area (i.e., nearly zero change, even after my janky equalizing charge.)
Originally Posted By: oilmutt
Dont waist your time,go straight to Costco pick up AN, INTERSTATE BATTERY WITH AFULL 42momth free replacement.Costco is only second to REI when it comrs to returns,dont look BACK!
Originally Posted By: kc8adu
most likely true.
as i stated its in icu on life support and may pull its own plug without further notice.
sounds like that battery is headed for the recycling pile soon.
unless the 2 low cells got overwatered i would schedule replacement before first cold snap.
sounds like you have a perfect storm for getting stuck somewhere.
undersized and damaged.
you could try floating it a while at around 15.5-16v at low current.
i use a 1a dumb charger to do that.
but 2 low cells in the absence of spillage or overwatering is a warning to replace.1 low cell is the same.
hopefully it holds out long enough to find a good deal/coupon code,ect for its replacement.
as for the voltage dropping thats likely a heavy load dropping the line voltage.
measure line and see if it drops when the battery voltage does.
This very well may be true, but we'll see. I'll start a new thread when it does die, so you guys can say, "I told you so." FWIW, I was told the same thing when I drained my Civic's battery to dead once. There were a ton of doom and gloom posts and they were all unfounded. It went easily through winter and all conditions, and was starting just fine when I gave the car away.
I feel like there are many here who give advice based on what they would tell their gramma. If my gramma was in my position, I would tell her to replace her battery, too. For your average BITOG'er, who maintains his or her battery, why would one dead event and two slightly low cells (without any baseline new specific gravity to compare current values to) automatically warrant a battery trade out. I'm not the type of person who swaps out things for peace of mind, when there are no indications of needing to do so. At this time, I'll remind you that I'm giving you guys free reign on the "told you so" front if I'm wrong and post that my battery died on me 300 miles away from home, without any AAP coupon codes to use!
