quote:
Originally posted by brianl703:
Originally posted by 1 FMF:
[qb] feed 13.8V into any 12V lead acid battery, sealed or not, and it'll take as much current as it needs to charge without overcharging.
The only reason to ever use a higher voltage is for a faster charge, but the voltage MUST be reduced to around 13.8V when the battery has finished charging, otherwise it will damage the battery.
my understanding, and I can post links for what it's worth, is that charging a battery greater than 13.8V causes gassing, therefore voltage is held between 13.2-13.8 to maintain a battery.
when charging a battery, there is current regulation as well as voltage regulation by the charger. A battery's resistance is very small, so by just applying 13.8V to it, the battery will draw as much current as it can like you said. Isn't that why there are selector swithces on chargers, such as 2, 4, 6, and 10 amp settings?
My point was in order to maintain a battery, you need a charger that is designed to do that, and they will reduce current to 1-amp or less, with voltage in the 13.2-13.8 range. Any more current than that going into the battery will flow through it and boil off electrolyte via electrolysis, overheating the battery and eventually ruining it.
Leaving a cheap charger, like one with a min. rating of 2-amp, connected to a battery to maintain it will ruin the battery if left on long enough.
http://www.uuhome.de/william.darden/carfaq9.htm
http://science.howstuffworks.com/fr.../www.4unique.com/battery/battery_tutorial.htm
