What is the difference? Thank you and Stay Safe
Center differential ! A real good example of that is a large tandem axle truck, that rear axle assembly is always in its 4x4 mode, the differential in them is called an inter axle, it can also be locked for off road use, if it is not unlocked for hard surfaces that will not allow for tire slippage, those inter axles get ruined real quick.Some AWD vehicles actually have center differentials and drive front and rear wheels all the time, like Subaru and Audi Quattro. Others are FWD systems that occasionally drive the rear wheels when the front wheels start to slip, but those can be called AWD or 4WD. The 4WD/AWD on my Pilot is one of those, although it has a button to lock it in 4WD for use in low traction, but only in first or second gear. 4x4 systems on light trucks are usually rear wheel drive and can only be manually engaged, although the 4x4 on my Ram has an option to engage the front wheels momentarily if the rear wheels start to slip, which Ram calls "4WD Auto".
answeredWhat is the difference? Thank you and Stay Safe
This.I think manufacturers just make it up as they go along. My Dacia Duster is badged as “4WD” and it’s essentially a FWD car with a transfer box that sends power to the rear wheels when required. They recently facelifted the Dacia Duster and despite being the same four wheel drive system underneath, they’re now badged as 4x4.
Depends on specific system. AWD is all over map. 4x4 occasionally can be AWD .What is the difference? Thank you and Stay Safe
How about the new ford explorer they appear from the back end to have a rear wheel drive diff set up?Mercedes, BMW, Dodge Durango, etc. are AWD, but RWD biased. Some have two-speed transfer cases. Generally, more capable than 99% of FWD based AWD (except few).
Yep, they are RWD based.How about the new ford explorer they appear from the back end to have a rear wheel drive diff set up?
