quote:
Originally posted by Frank:
This board seems to lean to the theory that oil cleans. It doesn't every engine has friction points where third party abrasives lodge. These friction spots caused the engines to run hot. Synthetic oil coats the engine rotating parts
reducing heat, it does not remove third party abrasives, just lubricates around them. Keeping your engine clean makes good sense for most and
a major benefit for you Bob is your oil is going to perform better. We are not using solvents that will eventually create seal problems. We just cleaned a 2003 Lincoln with 670 miles the filter was full of metal shavings. As far as what you saw in your test i think perhaps you should redo it I am told Amsoil Dealers precleaning with Auto-Rx have more referal sales than there or someone elses engine flush.
Sorry frank but you appear to hang on this solvent issue which I find a little disturbing still. I don't use solvents in my engine and never knowly have as you well know I only use the neutra 131 and this solvent issue has been hammered to death as we both know the 131 neutra is no more of a sovent than auto rx which both have no negative effects on seals.
As for synth oils coats moving part to reduce the friction off parts? Did I miss something here? ALL OILS including MINERAL coat moving parts, not just synth's. Fact is, the base esters used by the auto rx is an oil which coats parts and partakes in doing the same thing. Of course the amount of this is minimal which has no real effect on the engine oils charateristics.
I tried your product.. It had no effects on my engine and to use it again will not change this end result. Does that make it bad? No, just proves that only an engine that DOES have problems with contaminents could benifet from this product. Since mine had been running Schaeffers oil, it didn't enhance any properties of my oil analysis from the trend I had already established nor did it produce any more evidence of dirt,grime or sludge in my filters both the one at 200 miles and the one at 500.
The point is, it's not going to get trash out of engine unless trash exists and a new engine doesn't have trash in it and a good oil such as M1 SS or Schaeffers or Amsoil will keep this from happening as long as one doesnt' extend past the life expentancy of these good oils. The oils job is to lubricate but a well balance additive package in a good oil will enhance the natural oils ability to clean, suspend and carry away debri left. As for cleaning shavings, Hopefully you don't have such in an engine.
There obviously is a lot of vague information on how your product works as it is so secret but I do have some conclusions which I guess I'll take the time to share and give you a chance to elaborate on so others can see there isn't much to this stuff and how it basicly works. Quite frankly, I'm really impressed on the concept.
As for the oil not cleaning comment. I disagree with that. Oil normal as a whole doesn't clean but carries away what the detergents / esters clean. From my little test of where I just put some old used valve stem seals in pure oil with no other additives and let them sit at room temp and no agitation, it was quite apparent that synth oils seem to have an excellent detergency and did an outstanding job of cleaning. It,like auto rx as explain by you previously, uses esters as part of the cleaning process. This is why so many synth oils causes leaks as they too clean the debri but leave a harnden seal that no longer works thus the leak appears. This is more common with older vehicles than newer ones also most likely due to different seal material? not sure about that last part. The other point is that auto rx does not fair that well in the same test, WHY?, because it requires heat and agitation, then it would work and even better than oil by itself.
The above mention test proves another point about bench tests.... As hammered on by many amsoil reps on here, Tech Data #'s produced on a bench test can't show the real true picture as my little bench test to show the cleaning ability of oils vers 131 neutra and auto rx. Auto rx does clean. It's technology is interesting to say the least but it will not clean at room temp nor just sitting there stagnet. It requires the oil to be warm, it also needs the oil to flow and get into fricitonal areas to work. So to test this product in stardard conventional means like you would any other oil will not show you a positive result, as do many bench tests on technical data sheets. Remember, only one aspect is usually being tested when bench tests are being run and it usually will not demonstrate the same results found in an engine.
