deanm11
Thread starter
Finally got around to using my micrometer. Different setup than planned - putting in cams/valvetrain upgrades and staying naturally aspirated on my Mustang build. Plenty of usable street power. I sold the ATI with a blower setup and picked up an Innovators West. The interesting thing is ATI says they make their bores purposely a little small to spec because otherwise you can't get the right fit on a slightly small of spec crankshaft snout. From what I see Innovators West makes there unit exactly to spec. Nice thing as I was blown away with how precise a reading I got on the crank. I must fully acknowledge that I am not a machinist. BUT. I measured twice reaching down not looking at the reading and came back this exact to spec 1.2500 each time. On that dial, 24 to 0(25) and 0 to 1 is one thousandth. Supposedly we're trying to be within about a 3 TEN-thousandth range. I'd say I can probably call the reading between those thousandth marks in about 20 gradations by my eye... e.g. maybe as granular as half a ten-thousandth. And the reading each time was clearly well within a ten-thousandth of spec. I would have though just pulling the balancer off the snout dry would have removed some material. A sheet of copy paper is approx. 4 thousandths. So getting precision to at least as small as one ten-thousandth is 1/40th the thickness of a sheet of copy paper. It was about 55 degrees in my garage.. but both the crank and the micrometer were colder... I think I had worked out that iron/steel would expand about half a ten-thousandth per 10 degrees F.
