I am going to be doing my third drain and fill on my 2003 3.5 liter Acura RL with 125,000 miles using Amsoil Signature ATF (one more drain and fill was done using Acura ATF when I changed it for the first time in 2006).
I have been fairly consistent in performing drain and fills about every 2 years or 30,000.
Is there any advantage to dropping the AT pan versus simply using the drain plug like I have been doing? Dropping the pan would also require changing the gasket I assume.
Also, I cannot find anywhere in the parts catalog that this transmission has a replaceable filter. Is that unheard of or is it simply how some AT's are designed?
Thanks for any help.
