The reason I used quotes was that I know the PPK doesn't convert the 335i to is. It does give it equivalent horsepower. The ECU software must have been the hold up along with waste gate configurations(there are now 2 versions depending on the waste gate in the engine). I inquired about buying it and could not. By the time one was officially available, I had decided that I was happy with it as is. If the PPK was available for the '08 and onward 135i, it was for the N54. The N55 came in 2011.
Now it hs been a few years, but here is the press release(sorry, inserting link on iOS doesn't work for some reason):
http://f30.bimmerpost.com/forums/showthread.php?t=820511
Originally Posted By: mightymousetech
Originally Posted By: Coprolite
Are you sure that you have an N55? I have a 2012 335i Sedan and it is N55. I had to choose between the 2012 335is E92 Coupe and the F30 sedan. There was no power kit available to make an equivalent "is" for the N55 until well after I bought the car in May 2012.
In either case, the engine definitely needs an LL-01 oil. I am putting in Castrol Edge 0w40 for the next change this month. It is pretty much the only LL-01 oil that I can buy at Walmart that I know of....at least in 5 qt jugs.
The 2012 335is coupe/convertible has the N54, the 2012 335i sedan has the N55. There was no real 335is sedan, putting the PPK kit on does not make it an "is", although the PPK was available, right from 2008 as it is the same kit sold for the 1 series.
So not sure what OP has, easy to check, does it have twin turbos or a single turbo. Unfortunately, BMW called both in 2012 "Twin Power" turbo.
