It came from Holbrook NY.
Mine shipped out of Twinsburg, Ohio
I will definitely be contacting them![]()
Mine said made in Korea.
I don't think I've ever gotten parts from either of those warehouses, so I'm not familiar with them
Have either of you googled your respective return addresses?
GM has been using Korean Iljin bearings in many of their recent cars. So Korea might not necessarily be a scam
Two things come to mind, what torque spec did you use? The fact Rock is not an authorized dealer and buys whatever they can from whoever they can the door is certainly open for fakes.
147000 miles. GM FWD sedans eat wheel bearings if they've got big V6s in them.How many miles on this vehicle? Seems odd to be on the 3rd set of hubs for a 2009 sedan, unless you're really putting the miles on.
Even so, that doesn't make a possibly counterfeit, any less so.
Is the bearing itself visible on the back and if so does it have SKF stamped (or laser etched?) on it?
I just got a couple of SKF and both had the SKF etched in the front. But the company that supplied one to Rock left their sticker on it, a company I never heard of. I will look later for the name.118-119 lb ft of torque. It had SKF stamped on the back of the hub however it was not Laser etched into the face of the hub like shown in the last picture.
Luckily I took one good picture before installation
I don't have the box, and the tracking number isn't that specific
But there's a Parts Pro warehouse in Twinsburg
Does RockAuto use them?
I know of Parts Plus, Parts Authority, and Prime Automotive as RA fullfilers, because I've been in them IRL around NYC
Last time I replaced this particular hub I went through 3 hubs because I was torquing the spindle nut when the wheel in the air. The 3rd hub I tightened the lug nuts 1st, lowered the vehicle them tightened the spindle nut. Lasted 5 years after that.Also, does this bearing replacement require any specific procedures?
For example, the Mk1 Focus rear wheel bearings in the drum require you to turn the wheel 10x in the opposite direction while torquing the nut down
Parts Pro seems to be part of Auto Value, so you should be safe![]()
Is this an actual documented procedure? I'm not calling you a liar, it just seems odd to me a unit bearing would care if it's loaded or not when torqued, plus it kinda defeats the purpose of time savings on the assembly line....? Am I crazy?Last time I replaced this particular hub I went through 3 hubs because I was torquing the spindle nut when the wheel in the air. The 3rd hub I tightened the lug nuts 1st, lowered the vehicle them tightened the spindle nut. Lasted 5 years after that.
No idea. All I can figure is if you torque it in the air without the weight of the vehicle on the on suspension and CV axle, the inner CV joint doesn't fully contact the back of the hub and properly set the bearing preload.Is this an actual documented procedure? I'm not calling you a liar, it just seems odd to me a unit bearing would care if it's loaded or not when torqued, plus it kinda defeats the purpose of time savings on the assembly line....? Am I crazy?
Geez I'd think the fine threads of the stub shaft would readily overcome any circlips and just pull either inner or outer apart.....maybe notNo idea. All I can figure is if you torque it in the air without the weight of the vehicle on the on suspension and CV axle, the inner CV joint doesn't fully contact the back of the hub and properly set the bearing preload.
That's my theory anyways.
Yes but with the full weight of the car pressing the CV joint into the hub you get proper preload on some vehicles, others must be torqued in the air.Geez I'd think the fine threads of the stub shaft would readily overcome any circlips and just pull either inner or outer apart.....maybe not
