Any new VOA’s of PP EURO L 5w30?
You're very welcome 😉.
That said, it is very good oil. GTL base oil, plus Infineum add pack. I forget the add pack number right now, however, the add pack itself can be A40 approved if blended in a 0/5W-40 motor oil. It also passes the MB 229.52 engine test requirements, but Shell never bothered to get that approval, they only got MB 229.51 officially. However, the add pack is mature by now, and Infineum has constantly updated it to keep up with the European OEM approvals. This oil is the same as Shell Helix Ultra ECT C3 5W-30. It will work fine in pretty much any gasoline application and light duty Diesel engines.
Is this publicly available info? Could you link the source?
Thanks
Same exact oil. By the way, Dexos 2 will be discontinued in 2025, that is why the language changed on the PDS to "meets requirements of GM Dexos 2."
URL: https://www.shell-livedocs.com/data/published/en/117efabe-3311-4db8-a647-d8ddae2382f4.pdf
