Hello all!
It is being argued (in the HDEO forum) that "The detergents in HDEO reduce the film strength (surface tension) thus the ability of a lubricant to maintain that precious barrier between highly loaded components." [Ducati996]
The response given was that "While your point is taken, I suspect the generally higher HTHS of an HDEO compensates for that." [Garak]
On this subject then, my query remains as follows:
Does it mean that a 15W-40 will damage the engine components and possibly cause "excessive vibrations" (that is, over & above just the CAT converter problems due to higher ash, when used in a passenger car like the Honda Civic (R18 engine, for example) or the Mitsubishi Evo engines, etc. ?
It would be really insightful to hear actual experiences and opinions on this(above).
