Originally Posted By: Jesrolllin
...Oh yeah, did I mention I am an ASE certified technician and run 5 auto repair centers in tigard OR.
This is the only additive I have ever had noticeable results from.
Do you recommend this product to your customers? Using it yourself is one thing... Advising customers to use it another.
I have a new 2008 automobile with 3000 miles on it. I changed the oil after break-in (about 1500 Miles), and will change again at 7500 and every 7500 thereafter, using 100% synthetic as MFR recommends. I was considering adding Motor Silk at the 7500 OC. MFR does not recommend using oil additives (I realize MS is not an additive, but a one time treatment carried by the base oil), but if this works and causes no ill effects, I'm inclined to go ahead. The engine has a turbo and if this boron really does reduce friction, it seems that the turbo bearings would be helped by this.
I'm still reluctant, but have another 4500 miles to decide.
