Originally Posted By: Gary Allan
Believe as you please. Pete C. from WIX has confirmed this many times. It's supported by the simple fact that IF it was ONLY there to keep the oil filter full ...EVERY nitrile ADBV would be a BUZZKILL FAIL.
I don't doubt the silicone ADBV is better. I have seen reasonable results, however, with nitrile, in keeping oil in the filters. Obviously, the lower the temperature, the greater the disparity in the performance between nitrile and silicone.
IF keeping the filter full ...with the specifying of a silicon ADBV was a requirement, then the "meets or exceeds" claim by EVERY filter man would be a bold faced lie. If it was a requirement, the OEM would issue a disclaimer "USE OF FILTERS WITH NITRILE ADBV'S IS STRICTLY PROHIBITED".
Use the sensible logic train there. The ADBV doesn't have to hold indefinitely. It merely has to hold for so long.
How many carmakers actually require an ADBV when they come up with specifications for oil filters? I'm not trying to be a wise guy; I'm legitimately curious. Another question I'd have is how many filter manufacturers follow that. I know that nowadays, just about every filter manufacturer uses an ADBV whether needed or not (compare Wix with silicone ADBV and German filters with no ADBV for my Audi).
Ford's 300s didn't "require" an ADBV. They were nice to have, and came standard with the FL1A, when the CFL1 and other comparable filters of the day had none. Speaking from experience, even the nitrile ADBV made the oil changes less messy. Startup noise was also noticeably different - of course, I'm not talking about leaving the vehicle out in -40 C for two days, either.
As for nitrile, I still don't buy the argument about whether or not the purpose is to hold the oil in the filter or anything else. If oil drains out of the filter because of no ADBV or a cold ADBV, it's going to bring the oil out of the galleries with it.
