Sorry for another Honda ATF question but I couldn't really find the answer to my questions from reading a bunch of threads here.
I have a 2004 honda that i have used ATF Z-1 since new. Z-1 is not available from the dealer anymore. However I can get Idemitsu Type H ATF (which is Z-1) but it is expensive @ $10 per quart.
I would consider using DW-1 but I have heard from my mechanic that there are reports of older Honda transmissions not doing so well with it because the new fluid is thinner than Z-1 and older trans were not spec'd for the thinner fluid (even though Honda has back spec'd DW-1). Comparing DW-1 and Z-1 specs they are very close. Z-1 is thicker @ 40C but they are pretty close @ 100C (6.8 vs 7.1) and they have the same flashpoint of 170C.
I've also looked at some alternatives such as Valvoline Maxlife Dex/Merc (which seems to be thinner than DW-1 and Z-1), Castrol Multi Import ATF (thicker than DW-1 and Z-1) and Redline D4 Syn ATF (A little thicker than Z-1 but pretty close).
So my questions are:
1) Should I just forget about it and use DW-1? seems like it could be a synthetic version of Z-1 based on the specs.
2) Should I use one of the other fluids? Have read OK things about Castrol Multi Import ATF but read here that it shears quickly??
Thanks in advance for any info provided.
