Helicoil for low stress. Time sert for high stress, or where the fastener will be repeatedly removed.
I am genuinely shocked by the Timesert result in the video.
For example - I had a subframe bolt break while doing a bushing replacement on the Volvo XC90. That model is notorious for corrosion in the frame above that bolt. This caused galling, and, well, while there was overnight soaking with penetrant, working, and care, there ended up being breaking, and ultimately, it had to be drilled out and the threads repaired.
Big bolt. M14. Critical strength requirement. Torqued to 90NM + 120 degrees. A non-reusable bolt* that gets stretched on installation. Huge load.
The Timesert worked perfectly. Also, Timesert was the only one that had an insert as long as, or longer than, the original thread depth.
That is an important point in my use decision. Helicoil and others offered only a 14mm depth for a 14mm bolt. With Timesert, I was able to get a 28mm insert - for twice the thread depth. Twice the bolt engagement and twice the engagement in the frame itself.
That was the clincher for this application.
The broken bolt in the frame. Can’t really get to it easily.
Timesert installed.
Fixed.
*I don’t re-use them. The torque is huge. I need a big cheater bar to get to the 120 degrees, and you can feel the bolt stretch. I have a 14x1.5 mm thread chaser, made from a new bolt (because the old ones are stretched) to clean those threads before pressing in the bushing and installing the bolt. There are four subframe bushings. They hold the subframe to the frame, so they really are critical components. New bolts are about $5 each. This isn’t an area to save a few bucks by re-using bolts.
