UOA by Oil Analyzers Inc.
Driving conditions: 7 mile daily trips; driving on the beach; several days of 100F+ temps (including one week vacation in SC in June with heavy load); towed a guesstimated 1,400 pounds 200 miles to Rhode Island in Sep; no mods but spirited driving.
OEM turbo was replaced (with another OEM turbo) 50 miles into OCI due to excessive oil getting past the seals.
My last Blackstone uoa using GC is here . The last Blackstone GC uoa numbers are also below on the right.
Comments: Base number is below acceptable minimum; Sodium is at a MINOR level; Sodium sources: coolant (antifreeze), lube additive or supplement, and/or environmental contaminant; Your note [about the turbo] was taken into consideration; Lubricant and filter change acknowledged.
Equipment make: Subaru
Equipment model: 2.5L Turbo
Oil use interval: 7,988
Oil type & Grade: Amsoil SSO 0-W30
Make-up oil added: 1 qt. (last added 8 oz. 6,322 into OCI)
Miles on unit: 74,029
Air filter: Amsoil Ea panel filter
Oil filter: OEM Tokyo Roki
Overall severity of report = 3 Abnormal
(zero values omitted)
Iron 11 12
Aluminum 3 4
Copper 6 7
Lead 4 5
Silicon 11 14
Sodium 90 10
Potassium 2 2
Molybdenum 1 2
Boron 7 2
Magnesium 17 587
Calcium 3423 1812
Phosphorus 677 873
Zinc 755 1106
Lube chg Y
Filter chg Y
Fuel Soot Water Vis @ 100C: 9.6
TBN 4.01
Oxidation 38
Nitration 27
Given my driving conditions and that I had a new turbo installed, I thought the oil held up well. I presume the sodium is from when the turbo was replaced.
This is my first run on an Amsoil product and SSO is in there again. I’m also now trying an Amsoil oil filter.
Comments?
-Dennis
Iron 11 12
Aluminum 3 4
Copper 6 7
Lead 4 5
Silicon 11 14
Sodium 90 10
Potassium 2 2
Molybdenum 1 2
Boron 7 2
Magnesium 17 587
Calcium 3423 1812
Phosphorus 677 873
Zinc 755 1106
Lube chg Y
Filter chg Y
TBN 4.01
Oxidation 38
Nitration 27
Comments?
-Dennis
