Another member who didn't stick around and was knowledgable and does engine/oil testing basically said what Blue99 did. He got beat up for saying it but it makes sense to me. It seems to me that it would be hard to make a 10W-30 PAO oil that passes the Fuel Economy tests needed for GF-4. PAO's high viscosity index/low cold cranking & pumping viscosities works against it here IMO, especially in a 10W-30 oil (0W-30 would be easier since it can use thinner PAOs and rely on more VI improvers). A 10W-30 PAO oil is pretty much a straight weight oil...nothing in it to shear. An oil like that that passed GF-4 would need some super friction modifiers which costs even more money to include. One other thing that could be done is to blend the PAOs such that it is barely a 30 weight oil which is fine because it won't shear but I doubt that's enough on its own. Maybe I'm wrong here and someone will tell me why.
What I think is that API/ILSAC has accidentally driven off the use of lots of PAO in oils by the fuel economy requirements. By not having much more stingent performance requirements, they've also made high use of PAO usually not necessary...obviously since non-synthetic oils meet the specs.
