Motor spun a bearing 2 days after the sample was taken. New engine from Jasper has been ordered. I'm told the oil filter was full of metal shavings (brother-in-laws truck).
Make/Model: GM 8.1L V8
Vehicle: 2007 Chevrolet 3500
Code:
OIL ATM 10w30 ATM 10w30 ATM 10w30 Val 10w30
MILES IN USE 6,000 10,389 6,000 3,000
MILES ON UNIT 146k 140K 130K 123K
SAMPLE TAKEN 6/22/13 4/17/13 10/23/12 9/5/12
MAKE UP OIL 2QT 5QT 2QT 1QT
IRON 50 124 34 10
CHROMIUM 1 3 1 0
NICKEL 1 2 1 0
ALUMINUM 13 33 10 3
COPPER 1 3 1 0
LEAD 8 11 14 8
TIN 0 1 0 0
cADMIUM 0 0 0 0
SILVER 0 0 0 0
VANADIUM 0 0 0 0
SILICON 36 69 27 12
SODIUM 29 96 78 177
POTASSIUM 0 9 4 0
TITANIUM 0 0 0 0
MOLYBDENUM 166 150 144 31
ANTIMONY 1 0 1 0
MANGANESE 7 33 30 47
LITHIUM 0 0 0 0
BORON 62 70 67 0
MAGNESIUM 18 23 19 17
CALCIUM 3720 3495 3556 2298
BARIUM 0 0 0 0
PHOSPHORUS 729 769 727 773
ZINC 849 861 848 861
Fuel %
soot %
Water %
Visc @ 100C 11.2 11.2 11.0 8.9
Base Number 4.87 3.40 5.54 4.55
Oxidation 58 52 48 10
Nitration 15 15 11 8
Oil Analysis Comments:
Infrared results indicate Oxidation is significantly high; Cylinder region metals (pistons, rings, liners etc) are at a moderate level. Silicon is at a moderate level. Silicon sources can be abrasives (dirt, Alumina Silica), seals and gasket material, lube additive or lube supplement, and/or environmental contaminant. Replace oil filter and top off system with fresh make-up oil if not done when oil sample was taken. Re-sample in 3,500 miles or 65 hours.
Code:
IRON 50 124 34 10
CHROMIUM 1 3 1 0
NICKEL 1 2 1 0
ALUMINUM 13 33 10 3
COPPER 1 3 1 0
LEAD 8 11 14 8
TIN 0 1 0 0
cADMIUM 0 0 0 0
SILVER 0 0 0 0
VANADIUM 0 0 0 0
SILICON 36 69 27 12
SODIUM 29 96 78 177
POTASSIUM 0 9 4 0
TITANIUM 0 0 0 0
ANTIMONY 1 0 1 0
LITHIUM 0 0 0 0
BORON 62 70 67 0
BARIUM 0 0 0 0
Fuel %
soot %
Water %
