A friend of mine owns this vehicle, a 1994 Chevy Lumina Van, 3.8 LTR V6. 258,614 miles currently, the engine had rod bearings replaced years ago due to a massive coolant problem (intake gasket failed). I believe he has used the 20w50 since the bearings got wiped out, to maintain proper oil pressure. He drives this van almost every day, and thinks nothing of starting it on a below zero morning with no block heater.
11,500 miles on AMSOIL 20w50 and filters, 9-10 months. He uses AMSOIL filters, both for the full flow and the AMSOIL bypass system. Both filters were run for the full OCI, with 1 quart of make-up oil. Analysis by Schaeffer's.
copper 7
iron 23
chrom 1
alum 4
lead 4
moly 17
phos 990
zinc 1137
mag 28
calcium 3623
sodium 15
potassium 10
silicon 16
visc. 15.80
sulfur 8
oxidation 77
nitration 27
soot .1
Antifreeze,H2O, & Fuel all zero.
He is happy with the performance of the 20w50, and I see nothing in the report to indicate he should change his routine.
-Robert
copper 7
iron 23
chrom 1
alum 4
lead 4
moly 17
phos 990
zinc 1137
mag 28
calcium 3623
sodium 15
potassium 10
silicon 16
visc. 15.80
sulfur 8
oxidation 77
nitration 27
soot .1
-Robert
