Highly doubtful. Here's an article from SAE confirming Mopar Orange HOAT is G05 dyed orange, vs. Ford G05 dyed gold.
http://articles.sae.org/11284/
"The dye color of antifreeze has nothing to do with antifreeze formula or performance. Chrysler’s G-05 contains orange dye to distinguish it from a yellow dye antifreeze previously used. Other users of G-05 have yellow or even blue dye. However, GM DexCool, a purely organic acid type, also has orange dye, and this has been a source of service industry confusion. Fiat’s OAT, although a different formula, also has orange dye and it has been used in early production of the Dodge Dart. The new Chrysler OAT, however, will have a purple dye.
Petronas Lubricants is the Fiat supplier. CCI Manufacturing will provide the Chrysler OAT."
Never seen Mopar Pink antifreeze personally. Even old Zerex charts show Orange HOAT from Mopar as G05.
My prior Ram was a 2001 with a 360, and green coolant, one of the last before the switch to HOAT.
Zerex G05 does list one single specific Chrysler crossover number MS9769. If that's associated with whatever Mopar Pink antifreeze you're referring to it should be equivalent. It is for my factory fill Mopar Orange HOAT in 2012.
Mopar HOAT was replaced in the 2013 model year with OAT, and originally also dyed orange az seen in the SAE article which caused confusion - Mopar OAT is now dyed purple (but I've seen reports Fiat OAT is dyed orange) and I have no idea what Zerex coolant might cross with it as it isn't what my truck takes.
As seen it's best to refer to by spec number such as MS9769 than color.
