This is my situation too.I assume you don't have standing water nor humidity higher than 50% in the crawlspace.
I don't think you need any kind of special box.
My HVAC air handler is in my crawlspace. No problems.
In my mind I'm envisioning something like a mobile home small water heater.
Probably similar to the trailer hot water heater. I’ll look for a link to post.Still need pics. Curious minds want to see the installation.![]()
How far is the hot water tank from the lamp? The absolute easiest way to do this is the replace the lamp holder with one that has a receptacle:
https://www.homedepot.com/p/Leviton..._-301667438-_-1-_-n/a-_-n/a-_-n/a-_-n/a-_-n/a
If you're using the Corro-Protect, the power supply cord length is 12':
https://www.corroprotec.com/product/water-heater-anode-rod/#
No need for GFCI IMO. Corro-Protect also doesn't specify one
I thought about this. But don’t want to have any issues by NOT using the GFCI.
I think you're thinking of something different than what I'm aiming for with my application. GFCI presence or not shouldn't have any bearing on the tank leaking.It's not over doing it. The gfi could trip for no reason and you'll never know it until the tank starts leaking.
