Originally Posted By: Bottom_Feeder
Guys, I think some of you are forgetting that the ADBV only works in one direction no matter how it's screwed to the engine. Oil flows into the filter through the outer ring of holes and past the valve, but the valve stops it from leaving the way it came in. So logically, an ADBV-equipped filter mounted vertically (thread-end facing up) is not able to keep oil in the engine's passages above it because that's the direction that oil is supposed to flow through the filter. Why would an ADBV prevent oil from flowing INTO the filter? Think about it.
The only thing that would keep oil above a vertically mounted filter on the inlet side would be equal presseure on the filter's outlet side, and that has nothing at all to do with the filter itself. That's an engine design issue.
A filter that points up (like on a Subaru) does not need an ADBV which is why a filter made specifically for a Subaru like the 14460 does not have one.
+1 That's what I thought in my first post here, regarding common sense and not seeing the need for an adbv in thread up vertical mount situations.
And, the other poster is also correct, I've never heard of internal engine adbv either, (unlike bypass) but there are some engine filter apps not requiring an adbv.
