Not at all. It works just as well as before migration to XF.Anyone else had this problem?
If all your devices are using your WiFi connection try your cell phone using your data instead of wifi, if you connect faster then try rebooting your router.Blank pages or timed out. Eventually it loads at times. This took about 15 mins to be able to open the page after several attempts. When not logged in near instantaneous. This is on several devices all the same even cell phone. Oh well keeps me out of trouble with one member as I can’t easily say anything. Even posting the reply takes minutes or fails.
Can someone translate this gibberish to English?I tried all suggestions and ideas, and more, no luck, and fixed it this way. Works perfectly now. I have ipad iphone macbook, and a pc laptop, all wouldn't work properly on any browser or on a different wifi or on cellular. Minutes or fail to log in, out, or view but only when logging/logged in. The problem had to be on here and exactly at the switch. Will see how hard they are, or not, about this honesty .
And you're a new user but you've had this problem for a while now?I tried all suggestions and ideas, and more, no luck, and fixed it this way. Works perfectly now. I have ipad iphone macbook, and a pc laptop, all wouldn't work properly on any browser or on a different wifi or on cellular. Minutes or fail to log in, out, or view but only when logging/logged in. The problem had to be on here and exactly at the switch. Will see how hard they are, or not, about this honesty .
I registered under a new name, problem solved. It had to be the transfer. Rules say no, but I got no solution so fixed it myself. So if that requires execution so be it. So there it is clearly said.QP is much more savvy than me, but it sounds like your browser. I would clear the cache and cookies. Delete the bookmark you’ve got. Log in again. Create a new bookmark. See how it goes.
Honestly, on Chrome, Edge, and Safari, the site is super fast for me. Loads instantly. So, I don’t think it’s the site.
So the issue is with your 2nd account ? If not, it's pretty impressive to accumulate 1100+ posts in what, a month or so ?I registered under a new name
