Astro,
I'm struggling that you keep bringing up the Asiana crash. The NTSB final report say not one single thing about SFO ATC/NorCal approach operations. They were given a turn to final for 28L 14NM from the threshold and just slightly above glidepath, with instructions to maintain 180 to the marker, which they accepted without qualm. Seem's pretty simple to me. The Aisana crew mismanage the aircraft all the way to the seawall. How are you putting that on ATC? The first 6 categories of the NTSB recommendation are directly related to Asiana's training and SOPs. The rest relate to studies of impact forces and for SFO ARFF and emergency operations and communications.
Secondly, you and I both understand why the high & fast visuals. It's a direct result of your airline and every other airline trying to cram themselves into SFO when the weather allows. Visual approaches get you in quicker with reduced separation. If we move to RNAV/RNP/ILS approaches to get you on to more optimal glidepaths, the arrival rates plumet. The system ripples with nationwide ground delay programs & airborne enroute metering/mile-in-trail restrictions. Then it's ATC's fault again. If they clear you for a visual approach at 110/280K and you say "unable", what happens?
The part about ATC not observing that they were lined up on the taxiway? Can you from over 1 mile away tell that an object moving at 150mph is offset from it's correct path by 30 feet in the dark of night? The controller looks up, observes the aicraft on final is who he says he his, ensures the runway is clear, and goes back to other tasks. It's midnight in SFO. Reduced staffing means more tasks for the local and ground controllers.
Let me be clear. The controller is not off the hook here. Saftey of the NAS is a shared responsibility: period. But you came out in your very first post with an obvious bias against SFO tower and NorCal approach and I'm trying piece that together. For the record, I do not work at either one so I have no skin in this particular game.
