AC Condenser Fin Cleaner
willbur
Thread starter
sw ohio
Greetings-
Can anyone recommend a safe for car AC condenser fin foam cleaner? Apparently, some cleaners can damage AC condensers.
1.Frost King ACF19 Foam Coil Cleaner, 2. Arm & Hammer Biodegradable HVAC and Air Conditioner Coil Cleaner Foam Aerosol Spray, There are many more as well.​
Spray on, let soak for a few minutes.
Rinse with water after using, no worries.
Do you mean evaporator?
no- the condenser below front bumper and grill. Fins are quite dirty and AC is not as great as it once was. Plenty of 134 in the system and no leaks, good compressor, etc. My first step was to replace cabin filter and now clean those fins. Need a cleaner that is not damaging to aluminum
thank you- you have used these? No problems them harming the aluminum?
This works well and doesn't leave a chemical odor.
