'78 F150 PS fluid
Originally Posted by corvettemustang
Hi, I believe the recommended fluid is Type F, but if I can't find that is there a substitute that is acceptable? Thank, Larry
Even WalMart online has it, if it's no longer available in your local store.
I saw Type F ATF ; is that OK? Thanks again.
Just so you know, type "F" was what Ford used for transmission fluid decades ago. Slightly thicker than modern transmission fluid, some racers still use it in transmissions for firm shifts.
Originally Posted by kstanf150
Type F is ATF
No kidding? That's what is recommended.
Type F is ATF
No kidding
