75-140 is an unusual factory recommendation. It is much thicker than the normal 75-90 that is almost universal.
I have to believe that they have a problem or or other good reason to require it.
Sure, MAYBE it is only for the odd time that high heat towing is involved, but I would not take the chance.
Can you go to Jeep forums and see what the guys are using with success over the long term?
Now, wait a second: 75w90 and 75w140 are the same viscosity at zero. Its just that the synthetic oil stays thicker relative to the conventional oil as the temp rises, such that the 75w140 "behaves" like 140 straight weight conventional at 200 degrees.
Having pumped them both, they are pretty much the same at room temps as well.
I lied in my first post though -- today at Walmart, their 75w140 Supertech is $10.50 or so per quart....
