SAE 10 no longer exists.
The reason for this is to eliminate confusion in thinner oils. They came up with SAE 16, 12, and 8 instead. (See the table in the previous page.) SAE 10W and 15W remain.
There was NEVER an SAE 10 to "not exist"...nor was there an SAE15...and SAE 15W is a relatively recent invention along with 0W.
Oh, and 10W could never be considered a 0W8, so we are clearly on a roll.
Here's some (not all, I'm trying to get them all) J300s going back in time.
The "W" ratings are the MAXIMUM viscosities at cold temperatures...the SAE Grade is either a minimum or a range. in order to carry the 20W20 label, it needs to meet the maximum viscosity specs for 20W, and be in the range for a 20 grade.
first couple of charts are the modern ones, note that the "W" grades are at different temperatures.
Compared to the older ones that used 0F, and viscosity maximums, which were ultimately found to be not very good for predicting operation at temperatures below 0C, as the concept of wax formation and gelling wasn't understood or clear.
Note the absence of SAE10, SAE15, 15W, or 0W.
Last one is the oldest I've found...
Here's a CITGO monograde chart (they dropped 20W20 recently on a lot of their lines, but nearly every 20 these days would be a 15W, or 10W20 in reality, with an HTHS of around 2.9, same as the minimum for an ILSAC 30).
the 10W is clearly a 10W, not a 0W...
The CCS at -25C is 4,000, and using the doubling per 5C drop (even assuming no wax formation) couldb't cross into 5W territory....MRV is a different matter, but the MRVs are puffed up to allow for teh effect of VIIs at low shear rates...the CITGO 10W's MRV at 10,000 (-30C) is indicative of little to no VII action (should have none, as it's a monograde).
It's KV100 at 6.9 (note that it's graded only as a 10W...there is no upper range for a 10W, and there is NO SAE10 now or ever) could give it a 12, 16, or (just) 20...HTHS of 2.3 would make it probably a 16, possibly a 12.
So a 10W...is a 10W.
And likely in the modern parlance a 10W16, or possibly a 10W12, and not likely a 10W20...but definitely not a 0W8.
Castrol Tection
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/5AB64AFC2F7027E780257A4B003AF801/$File/BPXE-8WPPFA.pdf
Shell Rimula X
http://www.alba.al/files/products/GPCDOC_GTDS_Rimula_X_monogrades_2.pdf
Oh and for giggs, here's the equivalent in CAT T04, when they started to run away from J300 as it wasn't suiting their needs.
Their specification of a max viscosity at a minimum temperature makes a lot of sense...but they aren't dealing with the impact of VII plastics either.
