Vehicle is a base model 2000 Subaru Outback Wagon with automatic transmission and 33750 miles.
This OCI history:
24Nov'03, changed oil and oil filter (OEM) with 3 1/2qts. Mobil 1 SS 10w30, 1qt. Amsoil S3K 5w30 and 4oz. Auto-RX...Used up all my stock of oil.
27Nov'03, changed air filter with OEM.
2Apr'04, at 3933 oil miles, changed oil filter (OEM) and allowing for the old and new filter drained enough oil to add 1qt. Mobil T&SUV 5w40...Since this was a winter run, I decided to change OF and try to replensish the additive package.
1May'04 added 4oz. LC...Just got it.
Used 2oz Lucas UCL in gas about once a month.
No other make-up added and still in service.
Oil analysis by OAI/CTC. 1st number is previous UOA and 2nd number is this sample. Sample dates are 17Nov'03 (~7 1/2months) and 25May'04.
I hoped to run this until the 1st week of August but with TBN at 3.28, I don't think it would make it by it-self. So I was thinking about draining a quart and adding a HD oil.
As always your comments and recommendation are greatly welcomed....bgin
This OCI history:
Had a mild winter, lows never dropped below 40*F. Drove about 65/35 city/hiway miles. Althou this UOA compares favorably with the previous, I have concerns with tin and sodium. The previous 3 UOA show 0 tin and sodium at 16,0 and 0. What can cause these 2 to jump? TBN has dropped a bit but oil is still in 30wt grade.code:
Miles on Samples 8366 6362
Fe Iron 11 12
Cr Chromium 1 2
Pb Lead 9 7
Cu Copper 12 5
Sn Tin 0 6
Al Aluminum 5 7
Ni Nickle 0 0
Ag Silver 0 0
Si Silicon 16 11
B Boron 75 88
Na Sodium 16 22
Mg Magnesium 32 108
Ca Calcium 2928 2709
Ba Barium 0 0
P Phosphorus 1067 1067
Zn Zinc 1277 1238
Mo Molybdenum 48 44
Ti Titanium 0 0
V Vanadium 0 0
K Potassium 0 0
Fuel %Vol
Vis@40C na na
Vis@100C 11.14 11.06
Water % 0 0
Soots/Solids na na
Glycol neg neg
TBN 5.08 3.28
Oxid 33 30
Nitr 19 18
Change yes no
