EQUIPMENT MAKE: Hyundai
EQUIPMENT MODEL: 2.7L V6
FUEL TYPE: Gasoline (Unleaded)
OIL USE INTERVAL: 3,084 Miles
OIL TYPE & GRADE: Valvoline DuraBlend 5W/30 (gas)
MAKE-UP OIL ADDED: 0 qts
ADDITIONAL INFO: Napa Gold 1334 Filter
MIKE: High wear is a common find in new engines such as yours. The wear is high due to break-in of new parts. We found some fuel in this sample too, and that's also common in new engines. It's there because the rings haven't seated completely yet, but it should disappear with the next couple of oil changes. It has lowered the viscosity a little, but not enough to worry over. The TBN read 3.4, showing plenty of active additive remaining in the oil. Once you're past wear-in, we don't think you'll have any problems going longer on the oil. Check back to monitor.
Miles on Oil 3084
Total Miles 4797
Sample Date 12/08/03
Unit/Universal
Aluminum 3/5
Chromium 1/2
Iron 16/21
Copper 75/44
Lead 5/15
Tin 4/4
Moly 0/17
Nickle 0/0
Mang 0/1
Silver 0/0
Titanium 0/0
Potassium 0/1
Boron 0/10
Silicon 20/39
Sodium 12/53
Calcium 2121/1523
Magnes 10/276
Phosph 732/795
Zinc 881/930
Barium 3/2
Sus Visc@210 56-62 tested @ 53.8
Flashpoint >365 Tested @ 305
Fuel Antifreeze 0
Water 0
Insolubles <.7 Tested @ .5
Miles on Oil 3084
Total Miles 4797
Unit/Universal
Aluminum 3/5
Chromium 1/2
Iron 16/21
Copper 75/44
Lead 5/15
Tin 4/4
Moly 0/17
Nickle 0/0
Mang 0/1
Silver 0/0
Titanium 0/0
Potassium 0/1
Boron 0/10
Silicon 20/39
Sodium 12/53
Calcium 2121/1523
Magnes 10/276
Phosph 732/795
Zinc 881/930
Barium 3/2
Fuel Antifreeze 0
Water 0
