Does that price seem excessive to have the coolant changed and the heater core flushed?
Indy shop which is about 1 mile from my house (I can run home.)Where are you going? Probably 1-2 hours labor and cost of supplies/chemical disposal.
Is there a drain plug?Indy shop which is about 1 mile from my house (I can run home.)
Granted the has to be put on a lift to remove the splash shield so the hoses can be pulled off the water pump (lowest point in the cooling system).
For the block? - NoIs there a drain plug?
I don't see why the system would need to be drained using the lowest point if it's going to be flushed.For the block? - No
For the radiator? - Not that I remember. There usually is a small plastic plug which will snap but it's not required to remove since the radiator is not the lowest point in the system.
Exactly. Why does the system need to be flushed?I don't see why the system would need to be drained using the lowest point if it's going to be flushed.
I'm no BMW aficionado but seems like this is being made really complicated. Drain system as low as it'll easily go, refill with distilled, run through heat cycle, repeat till water drains clean. Fill with appropriate level of coolant, top off with distilled, bleed.
If I'm missing something I apologize and am curious just how hard this can be made.
No problem. First I was looking to just have them flush the heater core at the To/From hoses rather than the entire system. Then change the coolant. The BMW way for the N55 is to pull the lowest hose and maybe the radiator drain (can't remember on this engine), vacuum test the system for leaks, then refill with fresh coolant with using the vacuum or manually. After which the electric water pump is activated for the 10 min cycle to burp air from the system, recheck coolant level and you're done.I don't see why the system would need to be drained using the lowest point if it's going to be flushed.
I just want to make sure the heater core is clear.Exactly. Why does the system need to be flushed?
Unless it is a known issue with this generation or there was contamination, there is usually no need to do this.I just want to make sure the heater core is clear.
4-series (N55). Because I want to make sure it's clear.What vehicle? Why is the heater core being flushed?
Ya, I can't do this at home. Infuriating but it is what it is. Heater cores can be an issues so I want to rule it out. I was just looking to black flush the core rather than flush the entire system.It seems pretty high to me. Two gallons of BMW blue is $60. However, if you aren't going to do it at home, then that's your price.
I would be suspicious of any flushes if they involve additives or separate chemicals. Is your series BMW prone to clogged coolant passages or heater cores?
That was my original plan and I might have reached that point by now if it weren't for COVID. I just realized that the vehicle turned 8 yrs old this month and I'm at 66k miles.Since we're talking about a BMW, wait until your water pump fails and have it done then...
