Another safety notice by yours truly:
So I was cruising around Home Depot earlier today checking out their Angle Grinders and related gear. I have 2 angle grinders, a cheapo chinese one, that I use to sand stuff with, and a cheapo Black and Decker, that I use as a chop saw.
Well I came upon these 1/8" thick metal cutting wheels and thought it would be good to cut up this L6 steel that I have in 1'x2' sheets into smaller bars for making knives.
I was almost finished cutting out what I wanted when I got away from my clamps and the 1/8" thick steel started to vibrate. No clamps were nearby and the steel began to chatter against the cutting edge of the grinder. Almost instantly the wheel grabbed and the steel torqued the disc just right to snap it.
I imagine that the 3600 RPM that my grinder was going, perhaps faster, the forces are pretty tremendous, because by the time I stopped it the 4.5" cutting wheel was nowhere to be found, just a few jagged pieces attached to the grinder and a sliver stuck though the steel I was cutting.
I had the steel guard on my grinder, had the grinder set up so it threw sparks AWAY from me, and wore glasses and long pants.
That being said, I think I need a face shield. If a 1" piece of that disc smacked my face or head I'm not sure I'd be out of the hospital yet. (I'm ugly enough, I don't need any cool facial scars.)
So, add a Face Shield to my short list of things I need.
Also, the fragments of that disc are stuck between the 2 nuts that hold them to my angle grinder.
The tool that I have to get the nut loose is bending before the nut loosens. So I hosed it down with Kroil and am letting it set up.
Anyone know of a better way to get that nut off without destroying the grinder?
Learn from me, be careful.
Stay safe!
Stay safe!
