Ever wondered what the temperatures, delta P, and fuel flow look like during a GM 3.0L Duramax regen?
The first graph is the Exhaust temperatures at the exhaust manifold and at the sensor just before the DPF. The high EGTs burn off the soot in the DPF. The second graph is the fuel flow and the DPF delta P. The soot is mostly burned out by about 6 minutes into the regen. The addition fuel flow sprayed into the exhaust is about 1 gallon/hr. This regen was entirely cruising at highway speed.
