In April 2004, received an analysis on the 10,373 mile sample showing Abnormal Nickel (36 ppm). Lab retested the sample at my request and it still came out high - 31 ppm. Suggestion was to test new oil fill at 4,000 miles, which I did. While the analysis didn't flag Nickel as Abnormal this time (only 4,063 miles), the trend seems to suggest that Nickel is still a problem and will be Abnormal within the 10,000 mile drain interval (factory, still under warranty).
No modifications have been done to the car.
Other elements also seem to be climbing. Air filter was replaced when this oil change was done, seal appears to be ok.
Help. Before I go to VW to have this recorded while still under warranty, I'd like to know what's going on in my engine. Expert opinions are welcome ! Thanks.
Viz
Lab: Oil Analyzers Inc.
Oil: Mobil Delvac 1 5W-40 (on all Analysis)
Vehicle: 2002 Jetta TDI
Viz
code:
Miles on Oil 4063 10,373 5,262
Miles on Unit 24,867 20,804 10,750
Oil changed
When sampled NO YES YES
Iron 43 118 48
Chromium 3 7 1
Lead 0 1 0
Copper 4 13 4
Tin 0 0 2
Aluminum 10 18 13
Nickel 11 36 A 3
Silver 0 0 0
Silicon 6 7 8
Boron 64 114 32
Sodium 4 3 3
Magnesium 484 565 495
Calcium 2564 2536 2880
Barium 0 0 0
Phosphorous 1150 1186 1185
Zinc 1356 1320 1326
Molybdenum 0 1 0
Titanium 0 0 0
Vanadium 0 0 0
Potassium 0 0 NA
Physical Properties
Fuel %vol
VIS @ 40C N/A N/A N/A
VIS @ 100C 13.74 14.21 14.4
Water %vol 0 0 0.05
Soot/Solids 0.35 0.5
Glycol NEG NEG NEG
TBN 9.61 5.86 12.3
OXID 9.0 10.0 7.8
NITR 17.0 18.0 17.1
F-Soot -- -- 0.51
