- Joined
- Oct 14, 2023
- Messages
- 231
Could anyone please tell me what certification is required for the ATF for the 7 speed automatic transmission on that Nissan?
It’s actually a 2018 X250 Merc with the same drivetrain. I can’t find what Merc prescribed for the Nissan’s unit.I suggest finding the owners manual for your country - should be online, Nissan manuals seem to be easy to find. Or ask at NicoClub.
The spec may even change by country. I know when they superseded Matic J with Matic S here, a lot of countries just kept using J.
I am assuming this is 2014+ given it has the 7 speed?
Nissan Matic S
Nissan Matic SDomain know what the spec is for the 2.3 liter Bi-Turbo diesel engine that in 2018 Navara?
That’s for ATF. What about for the the engine oil?Nissan Matic S
I think that your MB X 250d vehicle uses MB 236.14 specification transmission fluid.
That wasn't the question you asked.That’s for ATF. What about for the the engine oil?
I must apologize. I spoke with a Mercedes-Benz representative and was told that your 2018 model year vehicle uses a fuel efficient fluid, specification 236.15. This is the blue colored fluid and is designed for the 2nd generation of the 7G-Tronic 7-speed transmission.Where did you find this info. Could you please show it to me?
My suggestion for you is to contact a local Mercedes-Benz dealership and chat with them about the specifications for your vehicle (VIN specific). I wish I had more information to share but I don't.
Anyhow, this is from Nissan:
Engine Oil Grade
API CF-4 (NEVER USE API CG-4)
ACEA B1, B3, B4, B5
Viscosity
SAE 5w30 is Preferable
If 5w30 is not available, select viscosity based on anticipated outside temperature range.
Does your vehicle have the small diesel engine? Is it all-wheel drive?Thing is, it’s a Nissan’s 7 speed auto… Hence me trying to verify the spec accurately
Here is a snip-it out of a Nissan owners manual that addresses the transmission fluid. Again, without the specific details of your vehicle we're just grasping at straws. Also, there are several discussions on this forum regarding Nissan Matic S fluid. And for what it's worth, the specifications of the Matic-S seem to align closely with the M-B 236.15 fluid with the exception of the fluid color.
