Originally Posted By: StevieC
As for fuel dilution this can be fixed with more frequent oil changes and UOA's to confirm safe interval and/or using Bypass filtration unit. (Minor Trade Off)
Can't see how a bypass filtration unit will address fuel dilution. Please explain.
Because it's really good at super cleaning the oil. Amsoil's bypass filtration system for example will bring down fuel dilution in the oil so the oil can be run substantially longer.
As far as I can tell, to take petrol out of lubricating oil it would have to be:-
(A)using some exotic organic resin that did the equivalent of solvent partitioning, (in which case the resin would have to have a lot of capacity), or
(B) it'd have to be doing filtration at the molecular level, reverse-osmosis/kidney style, (in which case you could tip the petrol from it back into the tank every so often) or
(C) it'd have to be heating the oil (more than the engine does, but without cooking it) and distilling off the petrol.
I'd be surprised if its doing any of these things. (C) sounds most practical, but not all that easy.
