Originally Posted By: StevieC
Save your money.
Use something like Amsoil power foam through the throttle body regularly but just before an oil change or suck up a proper cleaner through a vacuum line regularly but at oil change time and use a properly rated high quality synthetic oil in between.
If you have done some homework on this matter before posting, you will find that deposits on DI engines are a completely different animal than traditional deposits. These deposits are extremely heavy and are not easily removed without Walnut Blasting or manual scraping. Chemical cleaners injected thru the intake tract will “barely make a dent” on the deposits if there is a decent amount accumulated.
We have Hyundai/Kia Direct injection engines in the family. This is why we use Amsoil power foam and they aren't having any issues. And yes they are the "Early" ones that had all sorts of problems. Like the Veloster.
Link to the product and ideally instructions on the exact process? Any warranty concerns with this product?
Save your money.
