2014 Silverado Diff Fluid Change
Michigan
Hello,
I need some advice, I have a 2014 Silverado with the G80 3.42 differential. I have about 20k miles on it and would like to change the front and rear diff. The front calls for 80w-90 non synthetic and the rear calls for 75W-85 synthetic. After much reading it sounds like I can use a synthetic in the front, should I stick with 80w-90 or just go to 75w-90 as I park outside all winter. Also, as far as the back I can't find many options for 75w-85, is it safe to use 75w-90? They recommended 75w-90 in 2013, I know that 2014 had a lot of changes but I can't find anything that says the differential changed to indicate it needs 75w-85. My understanding is that it's a CAFE thing. Anybody have info on that?
Thank you in advance for the help.
Ryan
75w90 for both and call it a day. Come back in anothe 50 to 80k for a follow-up.
Agreed. Call a fluid support line for any major company and they'll tell you 75W90 is acceptable for use.
Use either Mobil 1 LS 75W-90 or Amsoil Severe Gear 75W-90 in both the front and rear differentials. Should be good for 100K unless the fluid gets contaminated.
Differential, Front 8.25 RG......SLF [2]
All TEMPS......
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
Differential, Rear 8.6 RG......GL-5
All TEMPS......75W-85 [3]
Differential, Rear 9.5 RG......GL-5
[2] Synthetic Axle Lubricant 75W-90, GM P/N 88900401 or
equivalent meeting GM Specificartion 9986115.
[3] Synthetic axle lubricant GM P/N 19300457.
Differential, 8.25 RingGear Front..........3 pints
Differential, 8.6 RingGear Rear..........4.2 pints
Differential, 9.5 RingGear Rear..........5.5 pints
